![]() | Home > Technical (L322) > Range Rover L322 front parking sensors |
The front and rear are linked so if just one sensor fails the whole system shuts down... Do you have a way of checking through diagnostics sir? As it will show you whats working and whats not through live data... |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
The system shuts down if ones faulty from
Great minds Alistair |
ricky25 Member Since: 18 Dec 2018 Location: Leicester Posts: 17 ![]() ![]() ![]() |
Hi guys and thanks for the prompt response. No - I don't have any diagnostic testing kit available. What's puzzling me however, is that the rear sensors work perfectly and the front, not at all. |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Im far from an expert and excuse me if this is an obvious question, but did you turn on the front parking sensors ?? The rears come in if you select reverse but the fronts dont work unless activated. My mercs front ones werw on permanently as were the rears so when i got my first L322 i thought the fronts didnt work until i realised they have to be manually turned on. 2015 4.4 AB
Yes - I've tried switching the front sensors on manually but they still didn't work. |
@camtech Craig.. haha I agree sir. Both of us replied same time 😂 |
Norm Member Since: 25 Jun 2018 Location: Mississauga. Ontario. Posts: 32 ![]() ![]() ![]() |
If it's a sensor that's failed you can pinpoint which one by turning them on and then putting your ear up aginst each one in turn. You should be able to hear them clicking if working. Check the wiring close to the sensors it can cause a sensor to not work. |
