Home > Technical (L322) > Changed the Battery.... Now in Lockdown!
VogueSC-IOM
Isle Of Man 2006 Range Rover Supercharged 4.2 SC V8 Alveston Red
Hi there and greetings from a windy Isle of Man!
I have a 2006 Vogue 4.2 Supercharged with just 49k on the clock and have been having some battery issues recently, before giving up and replacing the huge 110AH Battery I tried a deep condition charge, but 2 days later she was dead. As a quick fix a Defender mate of mine offered me a spare 90AH slightly smaller Varta unit... Fitted it the other day, Started her up, All Good.... Tuned the radio.... left warming up for 5 Mins, all good, so I thought...
then.. went to move car, Gear selector stuck in Park, switch off and cannot remove key (like when you try to remove the key in Drive - key gets 9/10 home but stops there and will not remove). So just by swapping the battery, I've got a RR that starts and runs fine, but is stuck in Park and I have to use the 2nd key manually to lock the car up! Have tried battery back off for 24hrs, still the same after reconnect.
Brake Lights are working as well...
I'm thinking this must be resettable (hopefully) only error on dash is "Key still in" when you open the drivers door! Google not helping yet!
Post #498705 15th Dec 2018 10:26am
mjdronfield
Welcome.....
I’m not an expert, as touch wood, not had battery issues with any of mine.
I know if the batteries get low the computers can get themselves in a right mess. I trickle charge mine from time to time as I only do mainly shortish journeys.
Members have found doing a battery reset helpfull.... have a search, it something like disconnecting the battery and then holding the negative and positive cables together for a few seconds.
Sorry I can’t be more help.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #498709 15th Dec 2018 10:45am
VogueSC-IOM
Thanks for the welcome!
, I'll check that out, re: your cars... I had an M5 and a sierra cosworth!!
Post #498724 15th Dec 2018 12:36pm
Welcome
As MJD says try a battery reset.
If the vehicle is stuck in park it is being inhibited by the interlock on the transmission, which prevents the lever being moved out of park without the brake pedal being pressed. Get in press the brake and check that the brake lights come on, as I'm pretty sure its the same switch which does both, if you have no brake lights then there may be a fault with the switch.
As far as the key not coming out, that could also be an issue with Park. if the car isn't fully in P then it stops the key being removed. I would suggest investigating if there is full movement in the gearbox linkage or something stopping it fully engaging park. I reckon both things are connected and Park related. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #498741 15th Dec 2018 3:09pm
VogueSC-IOM
Will do the reset tomorrow after the storm! and report back
Post #498758 15th Dec 2018 5:42pm
VogueSC-IOM
Hi there, I have done the reset, and the key is still stuck in the Ignition and Shift lever is still stuck in Park... (Crap)
one thing the P is illuminated Red, I'm sure its usually Green, that might give us clue?
Post #498839 16th Dec 2018 6:08pm
VogueSC-IOM
found these
- getting out of park
- getting the key out....
will try tomorrow
Post #498846 16th Dec 2018 7:52pm
mjdronfield
Looks like you will be able to get it going, so at least you can drive to a garage.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #498865 16th Dec 2018 9:42pm
