Home > Maintenance & Mods (L322) > Massive creaking... |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Could be the ball joints on the front lower suspension arms. When they get worn they can make a creaking noise 56 TDV8 Vogue SE
13th Dec 2018 8:47pm |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 790 |
Just replaced the kink shaped arm , the one with the seperate ball joints, on both sides. Couldnt find any play in the other ones but its difficult to get enough force on them to spot play unless they are really knackered. They also have a large bush. Looks like thats the next step... |
13th Dec 2018 8:57pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1378 |
Its most likely the ball joints, and less likely the arms ... mine is doing exactly the same at the moment ... a very short term fix as per below ...
14th Dec 2018 12:46am |
That is it ! The two ball joints that are screwed in to the hub have just been replaced so it must be the ones in the lower arms. Many thanks for this |
14th Dec 2018 8:46am |
paul70 Member Since: 06 Mar 2018 Location: North Yorkshire Posts: 101 |
Definitely ball joints I'd say, had both sides replaced this year the noise was awful. Only thing I'd have done in hindsight was have both done at the same time and i'd have saved the cost of tracking as it would have only needed doing once. The part wasn't expensive relative to the labour and tracking doing. |
14th Dec 2018 9:06am |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 |
Unnecessary quote removed
14th Dec 2018 5:40pm |
Posted whilst holding a large tree but the replacement of the lower ball joints seem to have done the trick. Just front tracking to be checked now but the £70,000 hunters wheel alignment set up at my local kiwi fit is boogered !! |
21st Dec 2018 10:06am |
