Home > Technical (L322) > Has a spike in my voltage blown a Ecu somewhere (17volts)
Gml
Hello Lads
iv a problem with my 07 Vogue it a 3.6
Iv bring it to a few places now but they can’t seem to help.
It started one day while I was parked up ticking over
all my dash lights started flashing on and off and my radio was switching on and off also.
and at the same time when I put the car in gear it would start pulling away rapidly without me touching the Rev pedal.
and the same in reverse.
I took it to the first Mechamic and the told me that the aultaniter was putting out to much power overcharging.
So we changed it.
That sorted the flashing light on the dash and the electric problems.
but I’m still left with the gearbox problem.
It does run fine trough the gears after take off but continue to pull like mad when you stop at a red light and it puts the engine under a lot is strain
and you have to sit with your foot hard on the break to stop it pulling away.
Have you seen or heard of something like this before?
Thanks in advance for any help you can give me.
Post #497086 29th Nov 2018 9:31pm
Gml
I was talking to a very helpful lad from Australia about this 20!min ago and the computer locked me out and I had to make a new user name and password sorry for the inconvenience
Post #497088 29th Nov 2018 9:45pm
fisha
What does the engine speed do when you pull to a stop and put the gearbox in neutral with your foot on the brake ? Does it stay at idle or try to rev up. V8 or else ...
Post #497096 29th Nov 2018 10:48pm
Gml
No mate it stays at Adle not a problem when in neutral.
Only when you put it in drive does the problem start
Post #497103 30th Nov 2018 6:11am
Gml
Has the spike in the voltage (17 volts) blower my Ecu somewhere?.
Post #497166 30th Nov 2018 6:37pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Gavin,
do you know whether all faults were cleared after the alternator change & then any new faults read?
Without access to a fault code reader, it won't be possible to make any good diagnosis. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #497176 30th Nov 2018 8:50pm
Gml
Hello lads to anyone interested in the post
it was my Torque converter The bearing was Knackered apparently.
So £750 later we are back up and going.
thanks to anyone that responed.
and I hope this helps the next man with the symptoms that my one had.
after all his is what websites like this are all about info and other drivers experience
Thanks again.
Post #498493 13th Dec 2018 7:46pm
