![]() | Home > Technical (L405) > L405 FBH Telestart Receiver Fob Pairing - Solved |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7997 ![]() ![]() ![]() |
Isn't there a fuse you can pull ?
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 900 ![]() ![]() ![]() |
Thats a very good point! off to investigate... |
PLOG Member Since: 19 Nov 2018 Location: Teesside Posts: 25 ![]() ![]() ![]() |
Did this work, JCW?
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 ![]() ![]() ![]() |
All working. Pulled the fuse for the FBH and then upon re-insertion held the off button down on the fob, and it's all paired again.
Could you confirm which fuse no. you pulled Charles?
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
so glad it worked.
I received my remote today and removed the panel in the boot to reveal the same view as in Alistair's picture above. However, I can't see any fuse numbers... I can see two fuse boxes - the large one just under the ivory trim in the pic, and a smaller one that's behind a cut out in the sound insulation just below the bright yellow connectors in the pic.
Its the yellow 20a fuse at the bottom left hand side of the smaller fuse panel, slightly hidden by insulation.
Thanks, JCW. I did find the diagram an hour or three later when I was putting it back together! |
aljo Member Since: 04 Jul 2018 Location: west sussex Posts: 202 ![]() ![]() ![]() |
I assume it does have a remote reciever unit and ariel fitted ? |
The build sheet says “Park heat with remote”, so I would assume so. At least that’s what I’ve read on here. I can’t imagine anyone would have removed the receiver, but it seems pretty common that remotes aren’t passed on when vehicles change hands.
reciever I would of thought be in the rear o/s panel as per the picture
ive just taken delivery of my L405 and no remote climate , but I took the remote and reciever off my 11my RRS hopeing that it would fit a L405 |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 791 ![]() ![]() ![]() |
Now the InControl App doesn’t operate the Park Heat, only starts the RR, I want to add a second fob to leave at work. A couple of questions:
