Home > Maintenance & Mods (L322) > Autobox wont upshift |
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 |
Sometimes faults just appear if you've cleared the fault which you said was intermittent and everything is okay then don't worry to much
9th Dec 2018 1:37pm |
bruno22rf Member Since: 08 Mar 2018 Location: milton keynes Posts: 69 |
Could the XYZ switch cause this problem? |
10th Dec 2018 12:26am |
ChrisJJ Member Since: 31 Aug 2018 Location: Redcar Posts: 39 |
ta for the replies.
10th Dec 2018 8:24pm |
My XYZ switch caused an intermittent fault - sometimes whilst driving the car would go into limp home mode - I believe the switch moves with each gear change? |
11th Dec 2018 12:44am |
Didn't know that. Maybe someone can confirm its operation. |
11th Dec 2018 8:17am |
The fault happened again yesterday.
21st Dec 2018 8:26pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 965 |
The inhibitor (or xyz or gear position) switch tells the transmission ECU where the driver has positioned the gear selector lever i.e. P, R, N or D. It doesn’t change signal unless the gear lever is physically moved. The shift cable connects the two.
22nd Dec 2018 5:43pm |
ok thats a good place to start then and makes sense.
22nd Dec 2018 6:31pm |
Yes, ‘fraid so. The sensor is part of the transmission’s internal wiring loom, which isn’t cheap (around £180 from Land Rover), so you need to be sure that’s where the problem lies before thinking about replacing it. Have you any way of monitoring the live signal from the sensor through your diagnostics kit to see if it keeps spiking/fluctuating?
22nd Dec 2018 6:52pm |
. Was a right mission getting the £70 worth of oil back in it!
22nd Dec 2018 7:23pm |
Not gotten round to diagnosing yet as it's been christmas and haven't had the time.
27th Dec 2018 10:13am |
