Home > Technical (L322) > Electric window problem
Shambler
Having an issue with the electric windows on the ole fat one!
Rear passenger window goes down on its own if you have the master button on the drivers side in the on position but will then not respond to any buttons either the rear one or the front master buttons? If I push the window disable button to lock windows on the front drivers door it will work with either front or rear buttons?? Thought it may be a faulty master switch pack so swapped it for another but it hasn’t cured the problem😕 anyone any ideas??
Post #495892 18th Nov 2018 2:45pm
RSW
Hello Shambler
Did you get to the reason for this as a similar problem has just started to happen to mine?
My driver side back window drops if the unlock button at the drivers switch pack is off.
If I lock the rears then I can close the window with the drivers switch
Thanks
Post #497828 7th Dec 2018 12:17pm
