Home > Technical (L405) > Shall it look like this under an MY18?
Lonfred
Spain 2017 Range Rover Vogue SDV8 Carpathian Grey
I was changing to winter tires yesterday and took at the same time a look under the car. Just curious if it shall look like this or if some protection covers is missing on mine MY18. Second two pic shows unprotected cables and connections just behind the towbar, first two pics show an “empty” part in the center of the car. Looks a bit strange and I can’t remember that my MY17 had this empty space...
Post #496946 28th Nov 2018 7:43pm
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
Mine is exactly the same. I find it hard to believe that this car wades 800mm of water and yet all the electronics are exposed under the car....
Post #497631 5th Dec 2018 7:32am
Amazing
800mm
It can do but, should you do it is better to have and not need then need and not have
Post #497634 5th Dec 2018 9:19am
Charles89
Very good question. I see lots of Range Rovers going off road without problem. I myself have taken mine to a few off road centres and tested the true capability.. and up until I burst a tyre because of the 22inch wheels, all was going very well. As for deep water, I have never ventured into any deep water as yet.
Post #497638 5th Dec 2018 9:37am
RSW
My worry with those pics would not be water, but the chance of a stray log or rock smacking something underneath and causing damage or pulling out a wire if snagged on a branch.
Problem is with under body protection it then traps the mud and dirt and needs regular cleaning out
Post #497645 5th Dec 2018 11:03am
