Home > Technical (L322) > Rear right hand height sensor
steve1
United Kingdom 2006 Range Rover HSE Td6 Bonatti Grey
Suspension inactive fault described as above on icarsoft scanner, now both sides at the rear have dropped would the above description indicate that the sensor is faulty?
Post #497432 3rd Dec 2018 3:42pm
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
Would say that it wouldnt be both sensors.
Post #497441 3rd Dec 2018 4:39pm
steve1
That was my thoughts, why would both fail together? Front is still ok so would suggest it's not the compressor
Post #497442 3rd Dec 2018 5:03pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
What is the fault code? Can you check the live values to see what's being reported? Also take a look at the 4x4 info screen and see if the rear right wheel is showing as way off Shocked
It's highly unlikely both failed at the same time. Worth checking that it hasn't come adrift and the connector / wires are okay. Be careful working under the car / in the wheelarch though. Make sure things are properly supported in case the suspension drops suddenly. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #497459 3rd Dec 2018 6:50pm
steve1
Cheers Mike but it's a bog standard 2003 se so no special gadgets! Lol just remembered I joined the rac a few months ago so will test them out tomorrow
Post #497460 3rd Dec 2018 7:01pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Does the height adjuster do anything? If not, it could be the compressor. Both my rears dropped down to the bump stops a while ago. It was a faulty compressor in the end. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #497462 3rd Dec 2018 7:13pm
steve1
No i cleared the fault on the icarsoft scanner and it was still showing up, then the back hit the deck but front is still ok.
Post #497467 3rd Dec 2018 7:32pm
With a fail on a sensor on one side, it is quite likely that the car will seek to level itself, hence why both sides are down. Just fix the sensor not working and all should be OK. Rarely does a new sensor need calibration. .
Post #497487 3rd Dec 2018 9:15pm
steve1
Thanks for the advice joe I've ordered a new sensor so I'll see what happens
Post #497540 4th Dec 2018 11:06am
steve1
Post #497545 4th Dec 2018 11:29am
