Home > Technical (L405) > Where's the fusebox? |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 |
I think one of the aux supplie fuses are in the rear compartment / boot |
29th Nov 2018 2:47pm |
Jon S Member Since: 10 Aug 2016 Location: Exeter Posts: 32 |
The one I'm after is the aux supply for the Right back seat
29th Nov 2018 2:51pm |
Huwrhys Member Since: 07 Feb 2018 Location: Hornchurch Posts: 548 |
Either side of the larger drop down glovebox are some flexible bits that run along the sides. You can squeeze/press these down and it releases the whole flap to drop downwards. The interior fuse box is behind and to the left. It has a diagram on a panel which comes out describing the layout and amperage of the required fuses. Be warned they are very small and fiddly. |
29th Nov 2018 3:14pm |
OK thanks I'll have a go at this later |
29th Nov 2018 3:35pm |
Hairy Dan Member Since: 22 Jul 2017 Location: NW Durham Posts: 177 |
Relevant pages from the manual
29th Nov 2018 5:42pm |
Thanks for all the info- managed to get the glovebox off by pushing down on the two stays (not immediately obvious what I had to do tbh) then got faced with -NO FUSEBOX!! The I realised it was hiding behind some insulation, once I had removed this I could see it easily. I then realised they use MINI Blade fuses not the "usual" ones so had to put it back together and go shopping for some more fuses again!
6th Dec 2018 4:50pm |
