Home > My Range Rover > my l322 td6 blog
ianpl322
United Kingdom 2003 Range Rover Vogue Td6 Java Black
my l322 td6 blog
new on this site and recently joined the full fat club with this!
spent yesterday giving it a good polish and on Saturday ill give it a service, have a few plans which I thought would be nice to show you all, which ill update regularly.
Post #497007 29th Nov 2018 11:36am
ianpl322
had a play tonight with the rear entertainment system and got the PlayStation working. I'll have a look at the DVD player another time. the sat nav drive was disconnected so powered that up. is there any point getting a disc or are they massively out of date?
Post #497035 29th Nov 2018 4:03pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Firstly be careful it doesn't drain your battery overnight -- probably why it was disconnected!
You can get update discs -- you may want to consider updating the unit.
If it has a DVD symbol on the front it is the most up to date unit you can fit -- disc updates available
If it doesn't have the DVD symbol it's a CD, again disc updates available, but the system is older, slower etc
Hope that helps Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #497037 29th Nov 2018 4:30pm
Huwrhys
United Kingdom 2017 Range Rover Autobiography SDV8 Loire Blue
If it's the Denso system it's likely that the latest disc is 2018 (I think). There are some available on the web which are pirated copies but they are not only subject to copyright but are usually locked into Spanish or Polish for some reason, so the reviews state. May all be hogwash but I wouldn't risk it.
This site offers OEM discs at very low prices or so they say. They state they are original discs with 2 years warranty but then they would, wouldn't they.
This post has been edited by the site administration team
link deleted.... this disc is an illegal copy
I found this came up as the first hit when searching for Denso genuine sat nav discs.
Huw
Post #497039 29th Nov 2018 4:35pm
ianpl322
I did wonder about battery draining but will soon see in the morning.
Post #497054 29th Nov 2018 6:15pm
ianpl322
had a bit of spare time today at work so dropped it on the lift to do a visual inspection underneath!
pleased to report the only fault is the rear flexi brake hoses are a tad corroded so these have been ordered for the morning,
one of the bonnet stays were broke so a pair of new ones have been fitted.
on top of that my egr delete lit has been delivered and added to the ever growing box of parts. also sorted the spare key this just required a new battery.
so tomorrow it will be the following jobs for peace of mind,
egr delete and remap,
full service including changing oil in diffs,
2 rear flexis
bg induction clean,
brake fluid flush
change the coolant,
Post #497130 30th Nov 2018 12:39pm
ianpl322
so I didn't get the service done lol as wife had other plans so put some miles on here. not entirely sure the torque convertor is happy as keep getting a horrible drone/vibration around 2.5k revs and constant at 70 so will try and look at it tomorrow.
Post #497360 2nd Dec 2018 8:04pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Is the lift yours?
I would love a lift.........🧐
Jim
Post #497363 2nd Dec 2018 8:25pm
ianpl322
yes mate I own a little garage. I have 2 that's the big lift a 4 tonne one.
Post #497369 2nd Dec 2018 8:46pm
ianpl322
so tonight I left her like this! back tomorrow to finish.
Post #497875 7th Dec 2018 7:31pm
ianpl322
good riddance to this little lot!
Post #497989 9th Dec 2018 10:39am
