![]() | Home > Technical (L322) > Creaky suspension? |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Update- the arms arrived today. Ordered them yesterday from Island 4x4 in Kent. Just fitted them- 45 mins per side. Quiet as a mouse now! MOT retest in the morning, jobs a good un! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Scorchio Member Since: 28 Apr 2010 Location: Staffordshire Posts: 24 ![]() ![]() ![]() |
I had creaking noises too ... popped it into my local independant - ball joint on one side - �110 + VAT
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Edited Previously..
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 474 ![]() ![]() ![]() |
Apologies for resurrecting an old post, but it might help others at some point. The advice about using a trolley jack and spanner to 'ping' the ball joint out didn't work for me. What did work though was �5.99 spent at Machine Mart for a ball joint splitter (it looks like a tuning fork). A good whack with a lump hammer once it was in place and the hours that I spent fiddling were suddenly forgotten. If you do buy a splitter make sure it's a big one - mine has a 22mm slot.
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 222 ![]() ![]() ![]() |
I embarked on replacing front and rear arms and the rear arm ball joint, but all did not go well so beware.
lister6520 Member Since: 17 Nov 2015 Location: Zebbug Posts: 5 ![]() ![]() ![]() |
I have a somewhat unorthodox method for removing stuck ball joints when all else fails.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8520 ![]() ![]() ![]() |
Hmmmmm....
I did say 'when all else fails', that is all else up to and including a hydraulic extraction but short of an oxyacetylene torch or explosives.
This was the ball joint. It was not the tapered fit to the suspension arm that was the problem. It was the plated casing and bolted flange totally bonded to the knuckle.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated :mrgreen: 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4 2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4 2002 4.4 Vogue 2000 4.6 Vogue 2010 Freelander 2 TD4 HSE 2009 Freelander 2 TD4.e 2009 1992 Mercedes 300D 1986 Renault 2.1 Turbo D 1976 Morris Marina 1.8 |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
I have just done this on the passenger side of my 2012 today.
ramigojag Member Since: 29 Oct 2018 Location: Sydney Posts: 17 ![]() ![]() ![]() |
I once did a similar job on my old E39 M5, similar looking ball joints and was a pain to remove, I bought a pickle fork to break apart the joints no luck.
Simran0211 Member Since: 10 Jun 2016 Location: Coventry Posts: 299 ![]() ![]() ![]() |
cant see any photos im in the middle of the job now |
