Home > Technical (L322) > iid tool 4.2 sc favour needed
dingg1
anyone help me out with this?
I have popped up lean codes for a few days now and when this has happened before its usually a vacuum leak at the breather hoses on rs of engine , now I have checked and double checked for any air getting in and can't find any.
so my next train of thought is the MAF going bad
I get the following on a hot engine
idle 5.8-6.2 g/s thats after giving it a bit of revs
1000 rpm 7.6
2000 14.7
3000 25.8
4000 35.6
can anyone with a 4.2 s/c do a comparison for me?
thanks in advance Thumbs Up
Post #496482 24th Nov 2018 12:24pm
Mulcher
England 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
I’ll give it a go on Monday afternoon for you. If somebody else beats me to it that’s OK I’ll check it out anyway then you can get a better average. 2006MY 4.2 SC
BMW R1250 GSA Rallye TE
Triumph Tiger 1050 (sold)
1979 Pontiac Trans Am (sold)
Post #496528 25th Nov 2018 12:32am
dingg1
thanks mulcher
its the unsteadiness of the idle count thats suspect but I took one reading at idle then another after the 1000rpm X 4 stage readings and thats when it started fluctuating a bit , if you do it in the same manner that would be great. Thumbs Up Thumbs Up
Post #496547 25th Nov 2018 9:26am
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I should be able to check this for you today Thumbs Up
Post #496564 25th Nov 2018 10:31am
stu1
Here ya go - this was with the following conditions:
Air temp 5 (as read by the car and indicated on the dash)
Oil temp 85 (Oil is Castrol 15990F Magnatec 5W-30 (changed in July) )
Coolant temp 92
Air con switched off (check you had this off)
Readings via IIDTool BT.
Car hd just driven 20 miles. Engine has 84000 miles on it.
Idle - 5.5 (this was varying between 5.4 and 5.6 but was mainly at 5.5)
1000 - 7
2000 - 14.5
3000- 23
4000- 34
There was no noticeable wobble at any of these RPM's.
Hope it helps Thumbs Up
Post #496585 25th Nov 2018 1:24pm
dingg1
thanks for going to the trouble of getting those readings for me
air flow meter was not the issue , discovered that the engine cover was pressing just a little bit on the breather hose enough to make the push connection (they are crap btw) a little squint in its recess and letting in a little bit of air.
problem now resolved
Post #496667 26th Nov 2018 2:02pm
Mulcher
Doh, just got back indoors after running the tests. Glad you sussed it, here’s my readings for interest:
Idle 5.9-6.2
1000 8.4
2000 16.0
3000 26.5
4000 36.5 2006MY 4.2 SC
Post #496691 26th Nov 2018 4:33pm
dingg1
thanks mulcher
all ours look in a similar ballpark anyway Thumbs Up
Post #496693 26th Nov 2018 4:39pm
