![]() | Home > Maintenance & Mods (L322) > Additional Battery Capacity |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
have you read this from the wiki,
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Just fit a split charging relay as used for caravans, that would sort out the charging. BMW i3 Electric Car
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 339 ![]() ![]() ![]() |
Thanks Stan;
AJGalaxy
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Never had a problem with the cables or the fuse.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3820 ![]() ![]() ![]() |
I have been trying to find out how the 2 battery system on the L405 works, but without the workshop Manual I am not getting very far.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
I believe dan_1984_uk did this ages ago (with write up?) - I have his car now and it is a lovely job. |
millerj90 You actually said "The problem I cannot seem to resolve is how to protect the 100A cable from carrying "starter current" when the vehicle is cranked.
Thanks both. I did read that thread and Dan_UK_1984 describes pretty much the same idea i.e. the need for extra capacity. Which is what got me thinking in the first place.
I have a second 110Ah battery fitted in the rear of my car connected to the 100A cable that serves the rear fuse board.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
I think you are skirting the real problem, what is causing the battery drain, my car often gets left for a couple of weeks between runs and I've never had an issue starting it.
Many thanks for the speedy and informative replies. The wealth and depth of knowledge on this forum is priceless.
aggraa Member Since: 16 Apr 2018 Location: diss Posts: 33 ![]() ![]() |
i had this problem with my BMW M3 , leaving it parked at airports/train stations whilst abroad. In the owners manual it said the car will drain the battery @17% per week whilst parked . I had no room to fit an extra battery so I got a solar charger and hard wired it to the battery and bought one of those little jump starter packs as back up . This worked well after I replaced the battery as it struggled to hold a charge after going flat 3-4 times .I bought a C-Tek charger but that couldnt save the battery. |
