Home > Off Topic > Smart meters |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Of course its for the benefit of BOTH parties as I explained in my case it would be quite involved to check in any other way and whats the downside? NONE
21st Nov 2018 5:32pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7940 |
Very interesting I'm renovating a house right now and thinking about aircon When you way 'heatpump' are you using a regular aircon air to air pump ? I'm likely not brave enough to go all in, so will fit gas central heating radiators and electric aircon |
21st Nov 2018 9:45pm |
I initially had air to air heat pump which on UK prices is just slightly cheaper to run than gas (mine had a COP of 3), I now have a ground source heat pump and thats even better. If I ever build a house of my own design, maybe next year when I retire, I would do ground source heat pump and underfloor wet heating to get most benefit. The flow temperatures are lower than a gas boiler so bigger rads are needed, underfloor works very well on lower temperatures. I would still retain some air to air units for a quick boost of heat or cooling in the summer.
22nd Nov 2018 6:52am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1534 |
Smart meters are there to also allow Time of Use TOU metering, I.e, higher tariffs during peak demand periods. Ron B. VK2OTC
22nd Nov 2018 9:53pm |
