Home > Technical (L322) > Bonnet release cable snapped |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
IIRC it is remove the passenger side inner wheelarch then employ a small monkey/marsupial to reach in and release the locks .
20th Nov 2018 6:00pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1371 |
It's probably broke at the join that sits near the wing line of the bonnet. I'd order both cables. V8 or else ... |
20th Nov 2018 6:29pm |
Danbhardy Member Since: 10 Nov 2018 Location: Chorley Posts: 44 |
Oh so there’s 2 cables?
20th Nov 2018 7:30pm |
And also what part numbers they are?
20th Nov 2018 7:37pm |
Won't help you open the bonnet.
20th Nov 2018 7:38pm |
I’ll get both if I can, but don’t know what I’m getting! Lol |
20th Nov 2018 9:09pm |
Give Dan at Duckworths your VIN and he will get it right for you .
20th Nov 2018 10:23pm |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Mine snapped at the pull handle. I managed to get mole grips on the end of the cable and pull it.
21st Nov 2018 8:58pm |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
When mine snapped I removed the drivers side wheel, pulled the plastic inner guard cover off, reached up to the drivers side front corner between the air ducting and grabbed the cable , pulled and it opened |
21st Nov 2018 11:47pm |
Ok, removed the passenger side inner wheel arch, but no access to the bonnet release?
24th Nov 2018 2:46pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35336 |
the cable is not on the passenger side, its on the drivers side.. |
24th Nov 2018 3:07pm |
Access from passenger side inner wheelarch to access release catches / cable on slam panel
24th Nov 2018 4:08pm |
Well we found it has snapped at the handle, but can’t see the remains in the hole to pull
24th Nov 2018 4:33pm |
Worth a try putting some hefty mole grips (or similar gripping/crushing tool) further up the cable to see if you can squash the outer cable and grab the inner in the process, then pull.
24th Nov 2018 4:48pm |
