Home > Technical (L322) > Tick Tock Tick Tock
keikeimok
United Kingdom 2011 Range Rover Vogue 4.4 V8 Stornoway Grey
Tick Tock Tick Tock
Hi guys,
These cold mornings when I started my RR, I noticed there was a faint tick tock tick tock sound somewhere in the cabin.
It was gone in like 15 mins.
Too much Jason Bourne lately.....
Post #496177 21st Nov 2018 12:17pm
rjff
Chances are it will be the Fuel burning heater.
Lots of info by using a search Cheers
Richard
Gap IIDBT
Post #496202 21st Nov 2018 3:08pm
+1 ^
FBH fuel pump, the heater will run to help heat the engine up quicker. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #496211 21st Nov 2018 4:40pm
rjff
You may even see (a little) smoke around the nearside?? front, gives a pause for thought Shocked
Have you a car build sheet available? If not a visit to vincoderz.com may give you the info when you enter your VIN in the relevant box.
Mind you, tick, tock could just be the crocodile with the alarm clock (He's behind you) Mr. Green Cheers
Richard
Gap IIDBT
Post #496224 21st Nov 2018 6:46pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
As above, it's more than likely the fuel metering pump on the webasto preheater Cheers
James
Post #496226 21st Nov 2018 7:26pm
keikeimok
hahaha... thanks so much for the info!
a little bit relaxed now, I was about to ask about my neighbor's K9 to make sure nothing dodgy underneath... HEE HEE.
Post #496284 22nd Nov 2018 12:17pm
