Home > In Car Electronics (L322) > Reversing Camera Upgrade
clemenz
Austria 2006 Range Rover Vogue Td6 Zermatt Silver
After reading a lot of topics about upgrading the reversing camera i decided to try it in my way.
I have a working camera, but as you guys know the image quality is bad, so i want to improve it.
I ordered some chinese cameras, power cables that fit the range rover 06 factory connectors and some
video cable that fits. Next thing, get a 3D scan from a factory camera. A friend has a faulty part that is removed
and organised to let it scan. Due the removing it got some scratches etc, that you see on the scan.
I want to print a 3D dummy of the existing camera so that it fits in the orginal braket, and then „work“ the chinese camera
by hand into the dummy so that it fits nice and looks good. (sry for my english)
due my lacking cad knowlegde, is someone interested to repair and provide the scanned camera so that i
can give the file someone for printing only? I will be happy to share the scan and help you guys to build
your own exchange camera if someone can prepare it for printing.
Thank you!
Post #496037 20th Nov 2018 9:43am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Clemenz - Hi !
What you're doing sounds like an interesting challenge !
However, it is a lot more work than the minor modifications required to fit 1 of the 10 Euro chinese cameras.
What extra benefit do you expect to get ? Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #496048 20th Nov 2018 11:10am
clemenz
I know, you have to source the right camera (check), get the parts for power connection (check) and to get the right video cable (pending but found). The benefit will be that you do not need to break your existing camera. i want to have an interchangeable camera. i can post some more details later at home (pictures, parts, etc.)
Post #496050 20th Nov 2018 11:28am
Pawl
Aaaagh - OK.
Good luck & please keep us updated with progress ! Paul,
Post #496051 20th Nov 2018 11:31am
clemenz
Ok, lets start with the information.
Power Connection (if you have the black connector).
You need a housing, the connectors and some cable.
Then you can crimp that stuff (i have not done it yet!).
Post #496149 21st Nov 2018 7:24am
clemenz
Camera:
As you guys know NTSC without lines, with mirroring.
I found one on amazon, shipped from china. I made a test with the
original LR cables.
LR camera with brake light, reversing light etc at night:
China camera, with ambient light:
Post #496150 21st Nov 2018 7:34am
clemenz
And now is the part where i get stucked. I need someone with CAD skills who can prepare and repaire the scan.
Post #496151 21st Nov 2018 7:56am
clemenz
Next Milestone reached: Camera reconstructed in CAD. Next --> Printing
Post #499654 25th Dec 2018 6:20pm
GGDR
Fantastic solution!
Well done Thumbs Up Thumbs Up
. Cheers, Greg
Post #499657 25th Dec 2018 6:41pm
clemenz
First print from 3D home printer, next step, sanding and painting. Then somehow move the electric into the plastic dummy!
Post #501578 14th Jan 2019 9:11pm
Mulcher
England 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Cool. Will follow this with interest Thumbs Up 2006MY 4.2 SC
BMW R1250 GSA Rallye TE
Triumph Tiger 1050 (sold)
1979 Pontiac Trans Am (sold)
Post #501593 15th Jan 2019 12:58am
Classic888
Reversing Camera Replacement
I am in the process of replacing the LR reversing camera on my FF. Found this on the bay. Item number eBay Item No. 142942635174. If you remove the existing camera components from the housing this aftermarket camera is a snug direct fit into the original space. Obviously you need take it out of the rubber housing it comes in. Sorting the wiring out tomorrow ( hopefully).
Post #501733 15th Jan 2019 8:48pm
clemenz
Thank you for that link.
I know you can replace the internal parts.
My goal is to have a solution whithout breaking the old camera!
Post #501739 15th Jan 2019 8:59pm
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
I saw an article for a reversing camera that doesnt need wiring, it works off the bluetooth function on your phone.
Anyway I ordered,it came ,I installed and it works perfectly.
Its from a company called NONDA. (nonda.us)
Took 15 mins to install.
Has a recharchable battery in it.
I'm perfectly happy with it for the times I'll need it.
cheers
Post #501743 15th Jan 2019 9:13pm
Busterbulldog
Wales 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
I bought a 2007 rangie last week with a non working camera, i popped the camera out, the fault was on the 4 pin connector inside the camera housing. I dremelled the connector off and soldered the 4 wires directly and all working fine. Quite an easy repair.
Post #501871 17th Jan 2019 9:24am
