Home > Technical (L322) > Found loose plug what could that be? |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I cant see the plug, there is an auxiliary water pump on the inner wing over that side you could look at |
20th Nov 2018 9:09pm |
KMMJE Member Since: 05 Mar 2017 Location: Vienna Posts: 6 |
Thanks, I checked the area...thats where the cable comes from and leads towards the back of the car....I just flipped the plug over so it would be better visible in the Picture...
23rd Nov 2018 2:41pm |
I will check mine. it may be something to do with the Fuel Burning Heater that probably isn't fitted to yours. |
23rd Nov 2018 5:18pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8632 |
could be for the diesel cooling fan. which may not be fitted in your region. There is nothing that can't be fixed with a hammer😜😜
23rd Nov 2018 5:38pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1536 |
If you note the colours of the wires, it's fairy easy to identify circuits by looking at the circuit diagram. Ron B. VK2OTC
23rd Nov 2018 9:09pm |
