![]() | Home > Maintenance & Mods (L322) > Rocker/Cam cover gaskets |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 940 ![]() ![]() |
I'm no expert on these engines but I'm about to tackle mine next week it seem the main cause is under bonnet heat which is high compared to most engines and Cooks everything plastic and rubber under the bonnet, i will be doing the 80 degree thermostat mod at the same time and inspecting everything else while I'm there.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
Yep had mine done 10 k again pass side bank is weeping going to try tightening the bolts first Current stable:
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
The manual only says to put a small amount of sealer either side of the half round cut outs but I smear the correct loctite sealer in the cut outs and along the back edge |
The irony is the garage did the bank which I think is leaking the one I did is fine lol - I am going to try to source the leak and tighten bolts around it first Current stable:
That's exactly what we've had to do to my mates m62 we rebuilt as the 1st attempt had a slight leak, will be doing mine today with a full engine service plus 80 degree stat mod. |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1393 ![]() ![]() ![]() |
When this happened to my 2004 4.4 I was advised that gasket replacement might not solve the problem, and that the alternatives were a new engine or a new car. It was running fine at the time, but apparently the leakage signalled something bad. I hope yours are not in that position. Only Range Rovers since 1988 |
Any further details? What did you do? Current stable:
A new engine would have cost much more than the car was worth, and by the time this happened (9 1/5 yrs, 97,000 miles) the car had for some time been in a "there's aye something" money pit phase, so I traded it in for a 4.4TDV8. Unfortunately I got no details on what would happen to the engine (other than keeping blowing oil out the back) had I just kept going with it, sorry. Only Range Rovers since 1988 |
Oh ok - if it was blowing oil out the back that's probably a different issue I too had that which was a duff pcv but nothing to do with the rocker covers Current stable:
