![]() | Home > Technical (L322) > 2011 FFRR 4.4 TDV8 Fuel Burning Heater problem |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 911 ![]() ![]() ![]() |
Perhaps the outside temperature is too warm for it to be triggered?
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Can you set the time in timed climate ? 2015 4.4 AB
Try turning off the ignition, then press the on butron for the radio/sispalu , then select timed climate and the options for heat or vent should be available. 2015 4.4 AB
dmhort120374 Member Since: 01 Nov 2018 Location: Rotherham Posts: 5 ![]() ![]() ![]() |
Thanks guys all working now!
Mickt Member Since: 08 Oct 2018 Location: South yorkshire Posts: 12 ![]() ![]() ![]() |
Hi guys reading this post I have same problem with mine ,-the heat or vent are not lit up,ive tried the test on the topic but no joy ,any other things I could try please ? |
Hi Mick
Hi mate thanks for prompt reply ill try that next ? |
Thanks Hort,just tried it sorted dont know how I missed that . |
