Home > Technical (L322) > Adaptive Dynamics Towbar/Towing Issues? |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 |
Well it will have active dynamics, but what that has to do with a towbar, I don't know. 2010 4.4 TDV8 Vogue SE |
13th Nov 2018 7:56am |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
HI, and I hope this helps.
13th Nov 2018 6:27pm |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
The main thing to bear in mind is that the towbar and electrics will work fine if you just plug and play...
13th Nov 2018 6:58pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2518 |
The car will know if a trailer is attached if the trailer's globes are incandescent or if load resistors are fitted to the trailer's blinker circuits. The CCF parameter is purely a build notation as to whether or not a trailer socket loom was fitted.
13th Nov 2018 7:39pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7828 |
But none of that is specific to later cars with Adaptive Dynamics, is it?
13th Nov 2018 8:40pm |
Perhaps someone suggested having adaptive dynamics might be an advantage if towing, with which I would agree. |
13th Nov 2018 10:25pm |
This prob explains it
13th Nov 2018 10:33pm |
I doubt that active dampers need to be told that a trailer is attached as they react to movement of the suspension and the vehicle as a whole, let alone that trailer weight can vary from a few hundred kg to 3.5T for the RR. |
14th Nov 2018 12:12am |
No idea why the tow bar people would ask if it’s got adaptive dynamics then. Interesting......
14th Nov 2018 7:26am |
therso Member Since: 05 Nov 2018 Location: On the move.....again! Posts: 6 |
Thank you for all your replies and comments especially rjff for the link to the build sheet. It shows '7 Pin X Bar Detach Tow Ball (028CC). I've clearly missed something. I take this to mean there should be a detachable towball plus all the towbar fittings etc.? |
14th Nov 2018 12:14pm |
Usually under the boot floor in a tray on the right hand side. 2011 Range Rover Vogue SE 4.4 TDV8
14th Nov 2018 12:40pm |
14th Nov 2018 6:18pm |
Following your link to vindercoderz.com I opened the build sheet for my vehicle and it clearly states on the second line: 'Towing Equipment - 7 Pin X Bar Detach Tow Ball (02BCC)'. Spoke with the dealer who insisted that there is NO towing equipment on the vehicle as was proved when I was viewing it. As he is the UK's largest L322 used RR (The Vogue Centre) I think I'll take his word. He explained that the original owners may have changed their mind and it was a not uncommon issue. |
14th Nov 2018 8:03pm |
Therso
15th Nov 2018 10:11am |
