Home > In Car Electronics (L322) > Strange box
A.Pires
Portugal 2002 Range Rover Vogue Td6 Zambezi Silver
Strange box
Hello all,
I have to remove the right side panel to access to the servo motor which is not good.
Attached to the panel I have this box with connections and 2 empty comunications ports RJ45.
Can someone enlight me?
My Vogue was equuiped by the previous owner with bluethoot for fhone by Bimmernav.
Cheers
Post #495339 12th Nov 2018 1:21pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
That's a Nokia CARK box Sir Wink
The larger port was for the cradle -- I can't remember what the smaller port did Sad
Bimmer used to sell ULF conversion kits, nothing to do with that box, though obviously the Nokia is a bluetotth kit! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #495342 12th Nov 2018 1:30pm
A.Pires
This plug with several cables was disconnected. Now I've connect it. Will it interfere with the ULF? Is this Nokia system better than Bimmer's ULF? This ULF is really tricky to pair with and hears quite badly when chatting and does not store the contacts.
Thank you
Post #495353 12th Nov 2018 2:14pm
Bushy30
All of the questions you ask are subjective!
I fitted ULF in my 2004 -- no problems at all
I also had CARK in previous cars -- no problem at all
The CARK won't interface with a ULF, totally different systems.
The ULF does store contacts -- are you aware that there are 13 different hardware versions of UFL, have a dig around in the for sale section (H-hum) there are a couple for sale Whistle
Hope that helps Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #495355 12th Nov 2018 2:21pm
