Home > Technical (L322) > TD6 not cranking, lights out |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I would check your battery connections are clean and tight as I had a problem that appeared to be a flat battery but was a poor connection although tight I had to clean inside the battery connection with coarse emery cloth.
12th Nov 2018 1:07am |
Fraynizzle Member Since: 27 Apr 2015 Location: Essex Posts: 111 |
my starter motor was quietly failing and i had lots of issues like this that seemed to be low battery.
12th Nov 2018 11:12am |
It sounds similar to the TD6 I worked on that had a faulty ignition switch but the thread below goes through a few things to check, methodical testing with a multimeter is the key in my opinion?
12th Nov 2018 11:08pm |
clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 183 |
Shame on me, i think the earth connection was a bit loose 😱 But i thank everyone fot the answers!
13th Nov 2018 8:05am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
..it happens, let us hope that was the problem .
13th Nov 2018 5:52pm |
13th Nov 2018 7:19pm |
