![]() | Home > Maintenance & Mods (L322) > Another water leak |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
No part listed for o ring so must come with sensor .they aren’t expensive tbh .
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 545 ![]() ![]() ![]() |
Blimey, no they're not expensive are they! Just assumed they'd be silly price. I'll get one and see if the leak stops.
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
There is no O ring for the sensor as there is no fluid at that join. The sensor is a magnetic reed switch and can be removed with the tank full. The tank splitting at the seam is the most likely culprit 2007 TDV8 VSE
Hmm, that's interesting. There is definitely fluid dripping from the bottom of the level sensor. Maybe it has sprung a leak in the header tank although this one isn't that old (the old one failed spectacularly!). I'll see how it goes.
