![]() | Home > Technical (L322) > Key battery problem. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Help please,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
bad news Mike...
Woofster Member Since: 12 Jul 2018 Location: Toronto Posts: 121 ![]() ![]() |
My apologies if this is slightly off-topic but when you change the battery in one of the remote key fobs, do you have to re-sync the keys so that you maintain the driver personalization settings that are designated to that key number? |
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 ![]() ![]() ![]() |
I don’t know what key you have but I’ve read about people changing keys and dropping the little black but that links to the car, sounds like it looks like a small piece of plastic but it’s inportant. Someone with more knowledge than me will explain more I’m sure. |
Thanks all.
i did mine recently so no re-code after battery change Mike, good luck chap |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
I changed myspare fob battery last week and no recoding needed! Cheers
Jomo Member Since: 26 Mar 2018 Location: Maidenhead Posts: 32 ![]() ![]() ![]() |
There are a few posts on here that suggest that the remotes can be sensitive to the brand of battery. Might be worth trying to get hold of a different brand. Duracell seem to get mostly positive comments and worked for me. 2011 5.0 S/C |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
+1 with Jomo, and check that you have put battery right side up (it has happened)
Friday morning update.
good news mike...all the best to your son and his bride..... |
Thanks Stan.
I have just opened a brand new strip of 5 Maxwells CR2032 batteries, dated Expiry date 12-2024 and out of 4 of them in Fob No.2 not one works. That fob had a Panasonic. battery in which I have refitted, and it works perfectly, but is giving low battery warning.
Updated Monday 14th Jan.
