Home > Maintenance & Mods (L322) > Fbh fuse
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
Fbh fuse
Hello I am confused
Looking to find the fbh fuse research on position on this here site means I don't know whether it's fuse 8 ,13 ,59
Can someone please tell me which fuse and where to find it mines a late 2006 in dash ignition
Trying to do a reset
Cheers Iain Thumbs Up
Post #494797 6th Nov 2018 5:10pm
srpara
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Fuse box passenger side
20amp
Fuse 59
Post #494799 6th Nov 2018 5:31pm
Henda
Cheers mate
That'll be the one behind the glove box
Bow down Thumbs Up
Post #494808 6th Nov 2018 6:13pm
srpara
Yes that's the one Very Happy
Post #494811 6th Nov 2018 6:46pm
Henda
Well pulled the fuse to reset the fbh still the same timed climate funs for a couple of minutes and turns off so it's looking like the fbh itself not sure what to do next I am reading about glow plugs or pcb , battery fault codes are saying unknown fault more investigating required
Post #494880 7th Nov 2018 11:28am
srpara
The fbh will only work when the temperature is below 4c ( I think that's it) any temperature higher and it will not run
Post #494888 7th Nov 2018 1:51pm
srpara
Have you had a read of the fbh write ups in wiki?
Post #494890 7th Nov 2018 2:07pm
Henda
Yes I've read them all confusing to me the timed climate should workbelow 16 degrees but it runs for only a couple of minutes then turns off and so far the fbh hasn't kicked in even at +1 so it's further investigation
Post #494917 7th Nov 2018 5:24pm
kooky_guy
Don't forget that you also need at least a quarter of a tank of fuel and your battery voltage has to be good.
Mine was behaving exactly as you describe but the battery rest voltage was 11.4v. A new battery seems to have sorted it. 2010 4.4 TDV8 Vogue SE
Post #494969 8th Nov 2018 7:53am
Lester Burnham
A quarter tank minimum, that could explain a lot, is that in the handbook? Never read that before but makes sense.
Post #495018 8th Nov 2018 3:27pm
