Home > Maintenance & Mods (L322) > Anoying L322
A.Pires
Portugal 2002 Range Rover Vogue Td6 Zambezi Silver
Anoying L322
I start to be disappointed with my Vogue L322. First it started with a knock at the right front suspension zone. I've replaced all the suspension arms, joints and brake pads. I've already undone everything and reattached it and the beat does not disappear. Then started with a squeak in the rear suspension almost looks like an ox wagon. Neither my 2A series with leaf springs made this noise. Then it started with a noise coming from inside the dashboard when I open any of the doors. This noise sounds like a little hammers hitting something. After a few seconds it stops.
It's near to go to the junk yard.
Ohhh how I miss my Discovery 200 Tdi.
It seems that where the best LR that I owned, not even the so much advertised Disco 2 TD5
Cheers
Post #493463 24th Oct 2018 12:15pm
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
Re the noise from the dashboard, is this any help:
http://www.fullfatrr.com/forum/topic49051.html 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #493469 24th Oct 2018 1:03pm
A.Pires
anoying l322
Hello,
Thanks for your reply. As per the youtube vĂ­deo it seems is the same that's on mine.
That AC blend motor what is the purpose of it?
Best regards
Antonio
Post #493473 24th Oct 2018 1:31pm
NobbyC
United Kingdom 2005 Range Rover Vogue 4.4 V8 Buckingham Blue
Re the squeak - quite common but before you go replacing suspension bushes etc, a cheap fix might be to check the routing of the handbrake cable as often the cable casing rubs through against the eyelets etc on both sides and then squeaks particularly over the slightest bumps.
Had this on mine and it was driving me mad and despite lubricating some of the bushes as advised elsewhere on the forum and replacing my lower hub bushes it was still there. Then by chance when I had the wheels off for a brake replacement. I spotted the problem - insulated the eyelets that the cable runs through and checked that the cable isn't rubbing against anything else. fixed now and not a sound since. happy days
Post #493504 24th Oct 2018 6:53pm
A.Pires
anoying l322
Hi NobbyC
I'm going to try that. But now I have a more urgent problem on it.
I'm going to put a new post.
Thank you again
Pires
Post #494518 3rd Nov 2018 2:39pm
Front end knocking, have you replaced the anti roll bar links (use LR ones if you do) .
Post #494520 3rd Nov 2018 3:08pm
A.Pires
anoying l322
Hi Joe
Yes I've replaced them but not with LR ones. Is that important?
Post #494528 3rd Nov 2018 3:58pm
