Home > Technical (L322) > Belt tensioner
A.Pires
Portugal 2002 Range Rover Vogue Td6 Zambezi Silver
Belt tensioner
About the TD6
Hi all
Due to malfunctioning of the air conditioner belt tensioner, the poly of this began to oscillate and completely destroyed the main belt. I have tried in several ways to remove the tensioner and I can not. I loosened the screw in the back, unscrewed the 2 screws that hold the body of the tensioner and it does not come out.
Any tips or procedure to withdraw?
Thanks
Antonio
Post #494521 3rd Nov 2018 4:21pm
When I removed this I couldn't get the arm assembly out of the tensioner body, but on undoing the two screws i was able to remove the whole thing (tensioner and pulley were OK, so not an issue)
The tensioner body should release and come off with a few gentle taps from a hide hammer or similar
Would post an image from RAVE but don't want to get into trouble with the forum's copyright Police Twisted Evil .
Post #494522 3rd Nov 2018 4:37pm
A.Pires
Tensioner
Hi Joe,
I also saw the images on RAVE and I did as indicated but I could not remove it and I was afraid to break something if it made more force. As I wrote earlier, I removed the two screws that hold the tensioner body and in addition to oscillating, did not come out.
Cheers
Post #494525 3rd Nov 2018 4:49pm
A.Pires
bel
Hi Joe again
But how can I remove teh complete tensioner if the arm don't let the body came out? The arn pass trhough an aluminium part which is part of the compressor or some part attached to it.
Post #494529 3rd Nov 2018 5:08pm
Fairly certain it is not attached to the compressor in any way, was able to remove the compressor without removing the tensioner body. The tensioner body just slots into the hole. Not sure why the arm wouldn't come out, and like you didn't want to hit it too hard! .
Post #494535 3rd Nov 2018 6:06pm
A.Pires
The tensioner as out. But for that I have to soak it with WD40 and a screw at the end, and hit that screw with a hammer.
The body of the tensioner has some signs of damaged probably due to bad bushes.
Probably to remove and replace that bushes the AC compressor must be removed and I don't take that risk.
Cheers
A.Pires
Post #494714 5th Nov 2018 4:14pm
Thumbs Up .
Post #494719 5th Nov 2018 5:54pm
