Home > Range Rover Classic > 2 door Range Rover |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3763 |
I was admiring a very nice 2 door LHD model fitted with a 2.5 VM diesel last week in Portugal.
29th Oct 2018 5:33pm |
nearlee Member Since: 28 Feb 2018 Location: Where the sheep are scared Posts: 249 |
The 2 door in UK is around 81, unless you find a CSK which was 91.
29th Oct 2018 7:22pm |
Classic888 Member Since: 10 Jun 2015 Location: East Yorkshire & Hertfordshire Posts: 233 |
Globally the 2 door continued in production until late 1993 early 1994. The Italian VM diesel 2.4 was fitted from 1986 until 1989. Then it was increased to 2.5 and marketed as the Turbo D. I am not aware of the factory using GM diesels, in the late 70s Land Rover did collaborate with Perkins on a V8 diesel based on the petrol V8 engine ( project iceberg) but it was cancelled as the blocks kept failing. In 1992 the VM was replaced by the 200tdi then in 1994 by the 300tdi. Hope this helps. |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 |
Thanks guys 👍 |
29th Oct 2018 7:34pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1373 |
You might find the odd 2-door registered later than 1981, my first RR was a 2-door Classic registered in 1983 (A reg), maybe it had been sitting for a while unregistered. Only Range Rovers since 1988 |
30th Oct 2018 11:16am |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2563 |
2 doors went on until the 1986 model year in the UK (CSK aside), they certainly didn’t sell many over here after the 4 door was introduced. Last 2 door was built in January 1994 - a van, for Portugal. |
30th Oct 2018 12:11pm |
annette Member Since: 07 Nov 2018 Location: Tilarán Posts: 30 |
15th Nov 2018 4:19pm |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1127 |
I,m going to look at this 1985 2 door soon.
15th May 2020 9:57am |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
That looks very, very nice indeed. 2003 Range Rover Vogue TD6 |
15th May 2020 10:02am |
