![]() | Home > Technical (L322) > Battery |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
My FFRR is fitted with a Bosch S4 013 battery which I believe is a conventional wet battery. It never has a problem starting the car, it does however not manage to retain enough voltage to run the radio or the FBH for any length of time - radio about 10 minutes, FBH - never unless the battery is on charge.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3817 ![]() ![]() ![]() |
Even with a new AGM battery fitted I don’t get much over 15 minutes listening to the radio with the engine off before I get the low battery warning.
I haven't noticed a low battery warning, it just switches off. I'll get an AGM battery for it, nearly everyone lists a standard Wet battery.
I have done it in about an hour, but beware, the hardest part is the physical effort needed to lift out the old one and lift in the new one. You also need a special 5 point torque bit .
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35634 ![]() ![]() |
can i suggest that you have someone to help take out and put in the battery..i held the left handle and giggled my side whilst my wife had the right handle and sorted her side ..
Apologies to Scuddriver, who is the author of the write-up in Wiki., Nino added his “table”
Thanks guys, all advice duly noted, I'll check my set of pentalobe bits, why DO they use these non standard specialist fasteners? drives me up the wall, stainless cap heads will go back in. BMW i3 Electric Car
My 2011 model has a fan fitted on the back of the charging unit, as can be seen in the photos, but don’t be surprised if your 2012 model doesn’t. Nino's 2012 Autobiography didn’t have a fan ?
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
Mine had the fan too, but rather than remove the module I took the whole bracket out, one 10mm nut IIRC |
There looks to be a lot of wiring for a charging unit! BMW i3 Electric Car
