Home > Maintenance & Mods (L322) > Correct towbar for exterior design pack? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8611 |
you could make the whole thing removable, and just fit it when needed. Or use a farmers hitch. There is nothing that can't be fixed with a hammer😜😜
28th Oct 2018 10:54am |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
There should be a cut out line on the plastic Current: 2011 FFRR Vogue SE 4.4 TDV8
28th Oct 2018 11:26am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Do you mean in the lower plastic panel held in with 4 clips? Current stable:
28th Oct 2018 5:55pm |
I do indeed Sir, there are other posts on here that suggest there is a clear line to cut to, I think CamTechCraig was the one mentioning it Current: 2011 FFRR Vogue SE 4.4 TDV8
28th Oct 2018 7:12pm |
This square line? I will try it - but then I’ve got to ask was the point of taking the middle cover off above it? So you don’t scratch the number?
28th Oct 2018 10:01pm |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 |
Hey Dan, have a look at this thread.http://www.fullfatrr.com/forum/topic48695.html I had a westfalia swan neck detachable fitted to mine a couple of weeks ago. The only thing I can't figure out is how to access the sockets - I can see them inside the bumper but can't figure out how to get to them
29th Oct 2018 9:10pm |
Cut it at lunchtime - it’s still fairly visible though is that right? I thought the point was to hide it? Also can’t access the electrics do they need moving?
30th Oct 2018 4:26pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Yes thats the correct fitment... The panel needs removing every time you use the tow bar... The small panel above that can be removed as to not scratch it when docking trailers...
31st Oct 2018 12:06am |
Thanks Craig I was thinking that was the way last night - typical LR laziness lol they want to the trouble of concealing 90% of the towbar with that bumper why didn’t they blow the cover slightly thicker to hid it totally Current stable:
31st Oct 2018 7:37am |
