is it permanent or does it sometimes disappear?
The connections to the glass are normally done by conductive rubber pads that are clamped or taped to the glass, I assume Land Rover do the same. You may find (if you're brave enough) reseating the glass would cure the problem on the other hand it may never work again. I would try applying pressure to the top and bottom around where the line is, it disappears you know the issue if it doesn't prepare to spend some money. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
