![]() | Home > Technical (L322) > Help with locating coolant leak. |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Not sure, if you look up that section on lrparts.ru you should be able to find it and if you click on it you will get a part number to google . ReaolOEM sute will give you the BMW part number if you search for X5 same year with M57 engine
From RAVE
tominator1982 Member Since: 10 Jul 2017 Location: Bristol Posts: 5 ![]() ![]() ![]() |
Thanks both,
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1427 ![]() ![]() |
Unlikely sinister. More likely to be failed / degraded seals given the age, the rubber perishes over time, not helped by the cycling of heat from the engine.
Hi and thanks,
In RAVE, "B" is identified as the coolant elbow which connects to the hose - coolant outlet elbow to changeover valve
Many thanks.
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
tominator1982 - If you just had a coolant change, connect a hose to the radiator drain tap and put other end of hose in a collection bucket or such and save your expensive coolant to reuse it again. |
