Home > In Car Electronics (L322) > TMC no longer working.....
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi guys any ideas here my TMC has suddenly stopped working when I go to search for a station it just scrolls through the search and stops at 99.4 and selects nothing where as previously it would stop at classic FM or Smooth for the signal for TMC. I have replaced the TMC with another module but still the same issue and its not showing any signal either in the signal indicator bar when its searching for the stations apart from when it hits 108 its a full signal but it just skips back to 99.4 and stops there. My radio seems fine also as good as you will get really on the L322! Any ideas much appreciated incase I've missed anything. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #492742 18th Oct 2018 10:10am
classic fm is the most used station for tmc but although you can receive the channel sometimes the tmc isnt on the carrier signal...
tbh the tmc is a waste of time as the info is normally out of date..i've had mine switched off for a couple of years and dont miss it..
Post #492751 18th Oct 2018 11:01am
