Home > Camping, Caravanning and Holidays > L322 2003 roof bars and roof box question
beninlondon
Hi all, thought I'd post this in here than the technical section since (I hope) those reading probably have encountered the same question. I own an 2003 vogue that has the roof bar kit and locking bars. I want to get a roof box but the bars that go accross the car are curved (following the shape of the roof) but don't they need to be flat for a box to clamp to them? I've attached a photo to show the curvature. Is this normal?
Post #483977 21st Jul 2018 12:43pm
no photo Wink .
Post #483978 21st Jul 2018 12:48pm
beninlondon
Done! Didn't realise I had to select it once I'd uploaded it.
Thanks for letting me know!
Post #483979 21st Jul 2018 12:51pm
Doesn't seem that bad a curvature. probably best to test a roof box on them, i would hazard a guess that there is enough "give" in the fittings to allow for the curve, and enough height to overcome the flat bottom of the box ? .
Post #483984 21st Jul 2018 2:04pm
Also check the width of the bars (front to back) - IIRC they are wider than the Thule bars and not sure if all roof box clamps will fit around them........
Post #483990 21st Jul 2018 3:05pm
beninlondon
Thanks all. I was wondering about the Thule vs Land Rover branded boxes. Thought they were the same, but perhaps the clamps are different. Suppose I should find one and find out! I want to get a bike carrier too but I think the curve in the bar may make it lopsided unless it's in the middle....
Post #484054 22nd Jul 2018 4:18pm
Andy
What roof bars are they?
Post #492707 17th Oct 2018 11:10pm
beninlondon
Factory fitted roof rails and cross bars!
https://www.lrparts.net/cab000040pma-genui...-2012.html
Post #492737 18th Oct 2018 10:28am
beninlondon
I've fitted the roof box and it fits great!
http://www.fullfatrr.com/gallery/albums/us...cture1.jpg
Post #492738 18th Oct 2018 10:29am
Andy
I saw a FFRR recently with roof bars, but they were fitted direct to the roof without the front-to-back bars if that makes sense.
Post #493371 23rd Oct 2018 4:51pm
