![]() | Home > Camping, Caravanning and Holidays > Swift with LED tail lights problem |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2942 ![]() ![]() ![]() |
My 02 FF doesn’t want to communicate with the Swifts lighting - the indicators flash rapidly. Swifts answer is to order a vehicle lighting module to fit in the caravan to regulate the voltage. Trouble is, they don’t know which one I need.
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
My camper trailer had led lights and I gave up with them, fitted old-school lamps instead. I read there is an interface that goes in between the trailer plug and car which resolves the problem, also read that the bulb out testing on the car can be switched off via diagnostics. Just to much $$$ and aggro for me so swapped the lamps
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
The problem is caused by the vehicle testing the 'bulbs' by giving it a very short pulse to see if theyre present and working. A normal bulb wont illuminate with the short duration pulse but an LED will. The modules have either a small resistor / capacitor network which slows the voltage rise at the trailer bulb or a timer circuit. I built my own using a handful of component putting a timer on each channel affected. The timer swuitches on it's output after 1/10 of a second, the short pulses are ignored. BMW i3 Electric Car
This is the module that Swift say you need. Trouble is, there are around 8 different types.
I couldnt agree more, if I'd been doing the programming I would have tested the bulbs at startup and then when theyre used. BMW i3 Electric Car
Can the bulb test be turned off with IID tool? |
I've just looked through the manual and I cant see it as a feature in there. BMW i3 Electric Car
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35474 ![]() ![]() |
hot and cold bulb monitoring can be switched off with the iidtool... |
SandySix Member Since: 13 Sep 2018 Location: Chippenham Posts: 44 ![]() ![]() ![]() |
OK so not sure on the terminology here.. what are hot and cold? While lights are on and while off?
Its not in the manual, I havent looked on the car yet. BMW i3 Electric Car
@sandy, its in the LCM ...cold is on start up and hot whilst engine running...
I'll have a look later, might be useful to be able to defeat it. BMW i3 Electric Car
I can only find cold monitoring in mine. I went into LCM and scrolled through and set every one to “no”. I’ll try it again when I get to the van |
I would have thought cold monitoring was the one, it will be feeding the pulses without illuminating a normal buld and can therefore show failure without the lamp being lit. Does it specifiy which lamps or is itglobal on/off? Im just wondering if it is configured for the trailer lights. BMW i3 Electric Car
