Home > Technical (L322) > crankshaft bolt
jk3528
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Zambezi Silver
crankshaft bolt
ok so lets have some ideas
put the flywheel locking pin in put 27mm socket on with big bar at first I snaped a short extention
tried it without and the locking pin snapped
so ????????????
just to check is it a left hand ie turn clockwise to undo
ir right hand ie turn anti-clockwise to undo
Post #491208 6th Oct 2018 6:00pm
GraemeS
Not your engine but the crankshaft bolt in a TDV6 is normal RH thread.
Post #491231 6th Oct 2018 8:21pm
jk3528
Thanks but as you said mines the 4.4 m62
Post #491240 6th Oct 2018 8:47pm
GraemeS
The picture in this link shows a RH thread on the bolt.
https://www.brit-car.co.uk/product.php/124233/5497/screw
Post #491250 6th Oct 2018 9:13pm
GraemeS
Note that if the bolt is single use (ie is a stretch bolt) then a new one will be required.
If the tightening procedure is to tighten to a torque then turn a number of degrees, eg +90 degrees, then you can be pretty sure that the bolt is single use.
Post #491253 6th Oct 2018 9:23pm
holidaychicken
It’s a normal right hand thread and you need the locking tool and even then I used a scaffold tube and 3/4 bar. I broke a 3/4 swivel head bar and had to use a sliding bar instead. You are at risk of damaging your relatively thin starter ring and then you won’t be able to time your engine correctly. The locking pin is for timing purposes only. I’ll post some pics of when I did mine.
As above it is a single use stretch bolt.
The Rave manual tells you everything you need to know.
Post #491271 7th Oct 2018 6:26am
holidaychicken
This is the correct tool to hold the crank while undoing the bolt, it’s a big lump.
https://rover.ebay.com/rover/0/0/0?mpre=ht...1280308528
Post #491377 7th Oct 2018 10:23pm
jk3528
Yep got one on order and a 3/4 drive socket
Post #491378 7th Oct 2018 10:26pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Dont forget the piece of pipe.
Post #491381 7th Oct 2018 10:49pm
holidaychicken
My breaker bar was over 5 ft long , bought a good scaffold tube off eBay guy for £6.
I tried to undo the crank bolt on a removed engine and even with breaker bar and two people holding the engine in place strapped to a trolley (engine not people) it just lifted them up when trying to undo the bolt.
I had to ratchet strap the engine to a sizeable plank of wood and park my range on the wood so I could undo the bolt which worked a treat.
When using the crank tool, a small block of wood between the arm of the tool and the right hand chassis rail when looking at the car works well for me.
I have loads of photos if you need anything
You may need 4 longer bolts to bolt the tool to the crank pulley
Post #491383 7th Oct 2018 11:33pm
Not done it on a RR but in the past when undoing a crank bolt I jacked the front of the car up put the socket on the bolt with the breaker bar fitted with the end of the bar on the drive or piece of timber and then let the jack down leaving the weight of the car on the breaker bar. Went for a coffee for a while whilst the weight of the car and gravity undid the bolt.
Could be worth a try. Thumbs Up
Post #491387 8th Oct 2018 6:26am
holidaychicken
Undone that bolt yet ??
Post #492589 16th Oct 2018 7:10pm
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Nice Thumbs Up
I've used a similar trick for hub nuts in the past.
Post #492611 16th Oct 2018 9:15pm
jk3528
All done now quiet easy with the right tool
Post #492621 16th Oct 2018 10:59pm
holidaychicken
Here's a pic of the holding tool with a pair of pliers for scale. That is solid steel as well, not a tube.
And this is my breaker bar, the thing that looks like a makeshift bonnet prop.
Post #492627 17th Oct 2018 4:20am
