Home > In Car Electronics (L322) > What phone in a 2007 L322?
SandySix
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
I have a phone holder in the centre arm rest of my Range Rover.. but anyone tell me what phone it is meant to take?
Post #492525 16th Oct 2018 12:28pm
that bit takes a cradle which an old nokia or seimens phone fits into...from memory the nokia is a 6210 ????
Post #492532 16th Oct 2018 1:18pm
SandySix
Ahh so there is a part missing.. bother!
That means the one I have for my AMG Merc would fit.. if only I can find a holder then!
Post #492535 16th Oct 2018 1:30pm
find a holder/cradle and then a phone which will be 2G and i believe 2G will be switched off soon..
Post #492536 16th Oct 2018 1:37pm
SandySix
From what I have seen 2G is expected to outlive 3G.. but maybe we are reading different bits of the internet! Or equally unreliable bits!
Phone is no problem - as I say got one of those for use in the built in phone kit in my AMG.. so would mean I can then use it in both.. result!
Actually.. wonder how the cradle in the Merc connects... Hmmmm
Post #492538 16th Oct 2018 1:46pm
this is the cradle you need,
and some more info here,
http://www.fullfatrr.com/forum/topic6434.h...one+cradle
Post #492540 16th Oct 2018 1:52pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
It was a rubbish solution btw - bluetooth was actually better. All the cradle gave was annoying text messages on the screen ...... I think I probably plugged mine in twice!! Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #492546 16th Oct 2018 2:08pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
I have this set up in my SL and put my regular phone on call forward. No blue tooth in the Merc.
I hope the 6210 doesn't become outdated overnight otherwise I'll have to spend fortunes on a Visseo. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #492572 16th Oct 2018 4:59pm
Woofster
Canada
Just curious but does anyone know how to remove that phone cradle altogether to turn that space into a storage area?
Post #492713 18th Oct 2018 3:05am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
On our 2006 tdv8 it was just a matter of opening the main cubby lid & removing the 6 torx screws that hold the top piece with the phone holder.
Then lift it up so you can get to the 4 screws that hold the phone cradle connector & the wiring connector.
Once removed you can put the cubby top piece back, but you will have a couple of inch square hole between the top & lower cubbys.
I filled the hole with a piece of convenient dense foam.
At least the top section is now large enough to hold my Samsung Galaxy phone .
I'll add a photo later. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #492728 18th Oct 2018 8:25am
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Please do, I'm very interested in this - would be great to have more storage Smile
Post #492807 18th Oct 2018 5:13pm
Pawl
OE Phone Cradle Removal 2007 MY
Rather than totally hijack this thread, I've added a fast write up of removing the phone cradle on my vehicle post at http://www.fullfatrr.com/forum/post492822.html#492822.
It's currently at the end Paul,
Post #492823 18th Oct 2018 5:49pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
We have a 2003 which has the same phone and it is still unused in the car. I'll take some pics at the weekend. I don't think it's a Nokia and it takes the old mega big SIM cards! I did put a SIM card in it once but never got it to work!
Post #492825 18th Oct 2018 6:04pm
siemens was the other phone make used....
Post #492846 18th Oct 2018 7:30pm
Baltic Blue
I think my cheap tracker works on the 2g network.
Does anyone know of one that works on other networks?
Mike.
Sorry if I have high jacked your thread. I am a bit tired tonight. Bow down G reg 2.5VM Vogue Portofino red 1991- 1999
Post #492848 18th Oct 2018 7:48pm
