![]() | Home > Technical (L322) > 4.4TD Cracked Inlet Manifold Questions - Restricted Mode. |
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 373 ![]() ![]() ![]() |
My car went into 'Restricted Mode' over the weekend a couple of times.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
Which side do you think has failed ?
I only reported one failed in my Fault Log, but several plenum were reported as cracked., but the most common failure is the 4 short rubber hoses.
It is the drivers side, but with a days fitting involved, I'd not want to chance a used one if there's a known manufacturing fault with them. May end up doing it again in six months otherwise.
Well it was a five minute shufty as I called in unscheduled. He seemed to feel the hoses all looked alright and due to the location of the soot on the engine cover, this signified a manifold. But final clarification would be when it's in to be done I guess. 2017 4.4 SDV8 Autobiography in black 2018 D300 SE Velar in champagne 1982 Rolls Royce Silver Spirit in green Spiffing wheel centre caps, L322 sill repair panels, etc |
This was the only previous manifold crack I found.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2660 ![]() ![]() |
The TDV6 inlet manifolds are on their 8th version although they got a year's head start on the 4.4 TDV8 with 2009 production. My son and I recently changed one of his 2009-built 3.0 D4's which took us 2 days although worse engine bay access than the L322 including interference from the EGR valve on the exhaust manifold, which is n/a to the 4.4 TDV8. |
Looking like the indy and the "about a grand" is the way then. And hope it's something lesser like the hoses or chamber when they start to strip it down.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Ive never heard of a 4.4 needing an inlet manifold changing yet! Plenty of 3.6's though...
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
I originally had this diagnosis on 4.4 when it wouldn't pass a pressure test after going into restrictive performance. In the end it was linked to exhaust blow between two sensors and a subsequent miscorrelation. Fault only came up when held at full boost for 30s+ Cheers
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
The air inlet manifold split on my previous car (4.4 TDV8) whilst in France a couple of years ago. 2019 L405 SDV8 Autobiography
I remember that case Buzz, but I must have mis- recorded it as a split in the plenum rather than the actual manifold.
Craig,
