Home > Technical (L322) > 06 Range Rover 4.4L AIR GETTING INTO COOLING SYSTEM |
Rlmichot Member Since: 14 Oct 2018 Location: LA Posts: 9 |
06 Range Rover HSE 4.4L
14th Oct 2018 7:04pm |
Here are the spark plugs, oil on them but no signs of being steam cleaned.
15th Oct 2018 12:28am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
If there is that much ‘air’ getting in then the sniff test would surely react if the gases were exhaust.
15th Oct 2018 6:55am |
Thanks for the replys. When you say sniff test is that the same as the chemical block tester? Tube in the expansion tank cap hole, filled with the special liquid that you suck air into? |
15th Oct 2018 1:05pm |
Just ran a compression test on all cylinders but the 1 with the stripped coil bolt. Only thing is I did the test with the engine cold. Being I removed all the plugs last night.
15th Oct 2018 3:56pm |
Yes a basic sniff test is using the chemical like the attached which i think you have already done, this isn't a definitive answer as your head gasket or block may only be leaking under pressure or high revs. I think garages have more sophisticated gas analysers. Compression test is good for the 7 you can check.
15th Oct 2018 5:43pm |
15th Oct 2018 6:16pm |
Are you bleeding it with the heater and blowers on full ?
15th Oct 2018 7:39pm |
Yes I am bleeding it with the heater on, it's a 06 4.4L how do I know if its jag or bmw? |
15th Oct 2018 11:47pm |
What do you think about putting compressed air striaght into the cylinders, piston top dead center on its compression stroke. If there's a head leak it should make bubbles in the expansion tank. |
16th Oct 2018 12:42am |
Regarding the engine you could google M62TUB44 and see if your engine looks like it, I know a bit about the BMW and nothing about the Jag.
16th Oct 2018 6:46am |
