![]() | Home > Maintenance & Mods (L322) > 2007 SC ZF 6HP Gearbox Auto Change Failure When Hot |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
have you tried lubing the selector cable. These can stick and cause the position sensor to give an incorrect reading.
Has Member Since: 19 Jun 2017 Location: Leicester Posts: 18 ![]() ![]() ![]() |
Thanks mate for the lightning fast response, any possible solutions will be acted upon! I'll take it to my mates place and we'll give it a go |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
My vote is for: "inhibitor switch" .
Thanks Joe90 for taking part |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
It’s not easy to speculatively troubleshoot issues with the Mechatronic unit, but fortunately it is easy to remove it and get it tested. I haven’t heard of it happening before, but could the transmission fluid temperature sensor possibly have failed, and it’s putting the transmission into a different shift mode when it gets hot? Solenoid problems are so common on early 6HP26s that it makes sense to eliminate these, and other Mechatronic issues, first from your enquiries before - if necessary - moving on to less likely causes. If your transmission works fine in manual mode, then it seems unlikely that you have a mechanical running gear problem and hence the issue is more likely to be control related (electronic/electrical/hydraulic).
Thanks Phil, always a privilege to hear (read) your wise words and honoured you have time in your busy schedule to respond to philistines like me |
