Home > In Car Electronics (L322) > CD Changer fault
gilesharrison
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
CD Changer fault
My 2008 L322 Vogue has the 6 cd changer in the glove box. There's a problem with it and I was hoping there may be an obvious fix. I've searched but couldn't find anything.
It will load any disc from the cassette, and will start playing track 1 off the disc fine, but when it gets to 51 seconds, it stops. Always the same time on track 1. I can't move it past that point with the controls and cannot skip to track 2. It's almost as though the laser is stuck and it cannot move accross the disc.
Any ideas? I was thinking about taking it out of the glove box and opening it up.
Post #492267 14th Oct 2018 3:09pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I had a similar problem with my CD player since I bought the car about 7 years ago.
About 6 months ago I decided to take it apart and see what was going on. It turned out one of the tiny motors was weak and kept getting stuck. I tried some silicone grease for lubrication but that made no difference. I ended up sacrificing another broken CD player and swapped out the faulty motor.
It has been perfect ever since. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #492295 14th Oct 2018 5:45pm
gilesharrison
Thanks Zebedee,
I'll take it out of the car and open it up for a look.
Post #492358 15th Oct 2018 6:50am
francy
United Kingdom 2004 Range Rover Vogue Td6 Zermatt Silver
Take CD player out open the flap get Cotten bud some methalate spirt on look at the far back inside for eye and gently wipe clean put back together then good cleaning disc in two or three times all should work fine
Post #492414 15th Oct 2018 1:42pm
