Home > Maintenance & Mods (L322) > Front fogs (LED) flickering?
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Im either going mad, or I did just see it. would my front LED foglights flicker? Ignition was on, and I'm sure they flickered a couple of times, as in not even a second each time.
And last week a mate was sure he saw them flicker too...
What could cause this?? Embarassed
Post #491310 7th Oct 2018 2:16pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
I dont know about Land Rover but some cars (my VW Touareg) used to pulse the bulbs for a very short time, not enough to heat up a conventional filament bulb to test if it was there and OK. LED's react quick enough to illuminate at full brightness momentarily. It sounds like may be a possibility. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #491314 7th Oct 2018 2:56pm
the FF has hot and cold bulb monitoring..both can be switched of with the iidtool..
Post #491318 7th Oct 2018 3:19pm
Exactly the same as the VW system described above... Known as Hot & Cold running as Stan says above Thumbs Up
Post #491323 7th Oct 2018 3:24pm
mrblonde
cheers all, so nothing to worry about Thumbs Up
Post #491325 7th Oct 2018 3:29pm
Yes & No sir.....
Im sure PC Plod might have something to say about flashing lights on the front of your car!
To be 100% correct, you should have the Hot monitoring turned off in the cars configuration files (CCF) As they are LED's you could switch the cold monitoring off too Thumbs Up
Post #491327 7th Oct 2018 3:36pm
mrblonde
Ahhhh good point....
I'll be clearing faults and error messages over the coming few days once the new front air struts have been replaced so will see about switching the Hot (& cold) Monitoring off
Thanks guys
Post #491330 7th Oct 2018 3:43pm
Post #491334 7th Oct 2018 4:06pm
AJGalaxy2012
Every day an education! thanks guys I didnt know about hot / cold monitoring or that it could be turned off with the GAP tool. BMW i3 Electric Car
Post #491342 7th Oct 2018 4:44pm
