Home > Technical (L322) > Engine system fault, now won't start - 4.4 TDV8
Ant84
*Update*
So I topped up another £15 of diesel last night and tried to start - no cranking whatsoever.
Today I had a guy come out at the expense of the warranty company and he plugged in his Autologic diagnostic, which came up with almost 120 fault codes. Had a look under the bonnet, he connected a charger to the old battery and he bled the fuel line of any air (he said there was quite a bit in there) and we tried again - started to crank but no joy.
It was getting dark around 6:30pm so I got my torch from the garage and set about swapping the existing (I suspect original) AGM battery to the new AGM battery I pictured yesterday. Second time of asking it finally burst into life.
Went round to my local Shell garage and filled another £40 worth of diesel, taking it to half a tank and now it's running nicely. Started up again right on the button so fingers crossed we're in the clear.
Having said all that, there must clearly be some kind of issue where the car is displaying incorrect fuel levels on the digital dash. I'd be looking for them to definitely fix that as I don't want to end up back here again. What's the likely cause of this?
Appreciate all the help you guys have given - thanks a lot.
Post #491137 5th Oct 2018 7:55pm
GGDR
Ant there are a few posts here, search "fuel gauge erratic".
Basically there are a couple of connectors in the fuel tank sensor that need changing.
. Cheers, Greg
Post #491139 5th Oct 2018 8:12pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Maybe read the link I posted previously? 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #491148 5th Oct 2018 9:59pm
