![]() | Home > Maintenance & Mods (L322) > Changing RR lettering- any tips. |
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 ![]() ![]() ![]() |
Use a hair dryer or a hot air gun on very low (and take care if hot air gun not to heat up to much) first to remove the letters with either a plastic scraper or old debit card etc. then use white spirit or acetate to remove any sticky crap left then stick your new ones on and put some polish on the paint around the area to protect until the next detailing is done. |
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 ![]() ![]() |
So with the white spirit and the sticky residue is it just a case of rubbing for a long time with a cloth? |
p-trax Member Since: 30 Dec 2010 Location: Hertfordshire Posts: 261 ![]() ![]() ![]() |
Pouring hot water on the badge softens the adhesive foam enough to allow you peel the lettering or badge off, leaving no residue |
dont forget to mark the level of the badge, i did this with masking tape at the far edge of the tail gate and a straight edge, V8 facelift Range Rover Autobiography 22" wheels.
