![]() | Home > Technical (L322) > ZF5HP24 Lock up - Solved |
unsolicited Member Since: 30 May 2016 Location: Bucks Posts: 130 ![]() ![]() ![]() |
Sounds like a failed battery. Both low and high voltage points to high resistance at the battery. Check connections are tight and cables in good condition first though. |
crowebeard Member Since: 19 Dec 2016 Location: Devon Posts: 93 ![]() ![]() ![]() |
The voltage reading was 13.9v when the engine was running, but I didn't think to check it with the engine off. |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
So the interesting one there is the over-voltage error.
Didn't have time to do a full test tonight, but will clear everything tomorrow morning and see where the IID Tool leads.
This morning all seemed back to normal with only the battery looking a little low at 11.9v. Went for a test drive and gear change was all smooth, but within a mile after I'd gone over 2000rpm the Battery, DSC, Brake System and ABS lights came back on and the car went back into (what I now recognise as) 'limp home' mode.
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Try to find someone who can refurb yours. A new regulator and bearings, jobs a goodun 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
