Home > In Car Electronics (L322) > navigation unit |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
Yes indeed Sir,
28th Sep 2018 11:40am |
sibelius Member Since: 19 Aug 2018 Location: worcestershire Posts: 19 |
So, are you saying that if the connections are bad the unit will not show up on the display screen? I will pull the unit out and check/clean all the connections, see if that fixes the problem. Thanks for the advice. |
28th Sep 2018 12:09pm |
I am indeed Sir -- exactly that! Current: 2011 FFRR Vogue SE 4.4 TDV8
28th Sep 2018 12:54pm |
That could be good news then, as if its only dirty connections it could just be a cheap fix!! There is a first time for everything, even where Range Rovers are concerned! |
28th Sep 2018 1:00pm |
If you're anywhere near West Oxfordshire and want to drop over with it we could always beat it into submission! Current: 2011 FFRR Vogue SE 4.4 TDV8
28th Sep 2018 1:53pm |
