Home > Technical (L322) > Headlights Misting and Breather Tube
slimsi
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Barolo Black
Hi - one of my headlights is misting up and reading the article below I should check the breather tubes, I cannot find any picture of the tube could someone enlighten me?
https://www.ovalnews.com/2010/11/tech-arti...rover.html
I also read people drill a hole in the bottom to clear this?
Thanks
Simon
Post #489786 24th Sep 2018 8:25am
i've never had this problem, maybe you have a dodgy light unit...
as for drilling a hole, this does help on the rear light units but not to sure if it would on the front as there are vent holes already..
Post #489788 24th Sep 2018 8:31am
mpirie
Like Stan says, drilling a small hole sorts out condensation in the tail light units.
The headlights have vents so you should not need anything more than clear vents at the front.
It may be worth taking the headlight out, removing the lamps and getting a hairdryer on low heat to dry out the inside as well as check the vents are clear.
Mike
Post #489791 24th Sep 2018 8:37am
slimsi
Thanks for quick replies looks like I will be taking the unit out Saturday to take a look at it...
Also need to work out why the heated screens dont work even though fuses ok.
Post #489806 24th Sep 2018 10:19am
