![]() | Home > In Car Electronics (L405) > WiFi / SIM etc - newbie questions |
NotNowJohn Member Since: 06 Sep 2018 Location: Edinburgh Posts: 30 ![]() ![]() ![]() |
Folks
Thanks for that - did you find a way to automatically connect your car to your phone’s SIM for mobile data services, or did you have to manually switch on the phone’s hotspot each time?
Huwrhys Member Since: 07 Feb 2018 Location: Hornchurch Posts: 548 ![]() ![]() ![]() |
I think my iPhone timed out so had to relink each time. The data is pretty low at 390mb over the last 3 months but I didn’t know what to expect so turned off the satellite view on the sat nav. My sim is 12gb over 12 months so I think I’ll switch it back on. |
Brilliant, thanks. Think I will get a SIM. I assume it’s a micro SIM? 2017 Range Rover Autobiography in Santorini Black with 22” turbines. |
It’s a micro sim. |
Got a data-only SIM from Three today, £14/month for 20GB on a 12 month contract. Seemed a great deal, installed and working a treat. Also allows the kids to stream both iPads simultaneously without too many issues, but will need to keep an eye on the data usage!
You do know you can get a 12gb sim for £30 which lasts 12 months. Should give you all year for £30 for all the data you need. |
Yes I do know that, but for the sake of £14 per month (which my business pays for) I can let the kids stream their iPads from the car's hotspot without having to worry too much. I was dubious if only having 3G would make this tricky but the manager of the Three shop said I can return the SIM and cancel my contract within 14 days if it doesn't fit my exact needs (I have this authorisation in writing). I have tested it out with both iPads streaming Netflix and the satellite view etc. on in the Sat Nav and no issues so far. We're planning a weekend away this weekend and we'll be going through some dodgy signal areas, if it works, great, if not, I can hand the SIM back and go to one of the cheaper ones like you mentioned, for sat nav stuff only. 2017 Range Rover Autobiography in Santorini Black with 22” turbines. |
Fair enough. I have a spare sim awaiting the first to run out but so far (no kids on iPads) still only 400mb. My phone deal gives me 60gb of 4g/month and wondered if it was best to use that rather than the 3 sim fitted in the car. Using the amount it does there seems little point in saving any. |
